Old 02-04-2020, 07:00 PM   #3
kingofqueenz   kingofqueenz is offline
Front is stock 15... swapping to a 17 is almost like circumcision, should be done at birth as it makes the gearing much taller.
With the 15 tooth stock I'm in 2nd gear before I leave my driveway
If you swap the rear, I suppose you may need to make adjustment to your chain (remove links etc. )
15 swap to 17 required no chain alteration or replacement, stock chain worked fine ...for now ( cue in suspenseful music )
