You didn’t bolt up snug did you? Make sure it’s not getting a mal aligned wheel hub, rotor or the wheel may have factory offsetting.
The Magnetic part has two wires from it. Push those babies in hard. Black and a double colored one.; I’m interested in seeing your bike on insta messages or something. The wiring harness I want to see yours, specifically the area just under the tank on clutch side of the case. Little connector with a 9 pin/6 pin box... has a Jumper wire black n white for the kill switch. PM ME
