Originally Posted by RedCrowRides
I am surprised that Grom exhaust fit , usually the exhaust port angle is different enough so that you have to heat the head pipe with a torch and bend it rather significantly to get a decent fit. The pipes for the DAX or "original" monkey ( not the new released one) will usually bolt right on .
Yeah, it didn't fit up. You're right. My 1st gen Vader had the same problem. I have it at a shop now getting fitted. Should have it Tuesday because of the holiday. Everything else has fit properly.
