Old 11-20-2020, 10:17 PM   #15
Musictrek   Musictrek is offline
Musictrek's Avatar
Originally Posted by hounderd View Post
my 2020 vader did the same thing when i first got it.
got it back home, replaced the cheap chinese fuel filter, fuel lines, spark plug and put in a vm22 (egr and airbox deleted). never had a problem since.
The problem was the vent hose probably kinked within the plastics of the top housing on the tank. Also, the check valve attached to that hose must be mounted upright or it wont work correctly and will definitely block the tank from venting or depressurizing. I recently got a Boom and found this problem on mine. The check valve in the pic is upright to work as shown. My finger also points to a pinch in the line as it wasn't routed very well
