No worries man! There is no emissions system on the bike to begin with. That SAIS supposedly just helps reduce down-rev popping / backfire. If you tune your carb correctly you won't have any of that to begin with.. Your charCOAL filter is your emissions, and your catalytic converter - if you haven't already replaced your exhaust.. I removed all that stuff; we don't do emissions testing in VA - WV doesn't even have laws against emissions / decibel restrictions period. You can run straight pipes off whatever!
Here's some info on your SAIS -
https://www.boosterplug.com/shop/cms...injection.html
What state are you in?
Just check your emissions laws to see if that is a required piece - haven't seen anywhere that requires it per say. If you replace your exhaust with a non-restrictive pipe like everyone else - then you won't even need that SAIS. And as far as emissions goes, if you do the exhaust - you're not going to be worried about emissions anyway, not running a catalytic converter anymore. So, pick your battle - I'll stay un-restricted! (like everyone else)
