Old 12-31-2020, 07:52 AM   #9
el-griffo   el-griffo is offline
rich idle circuit that can't be fixed with jetting you need to go up a size in carb?
Originally Posted by crackerjac View Post
What size did you end up buying? The 30mm? The manufacturer says all the slide sizes are the same and if you get a rich idle circuit that can't be fixed with jetting you need to go up a size in carb. I wonder if the 30mm I bought is too small going by their size/HP CC charts.
hi there, i'm confused (not difficult!) i would have thought that if the rich idle cannot be fixed by jetting a bigger carb would be even richer?
i have the same zong 230 crf clone engine and i put a pwk32 on it but it was way too rich in idle and i couldn't jet it down enough.
all the posts on the crf230 forum say a pwk28 is perfect for the stock engine.
apologies if i am talking rubbish - anyone put me right on this?
thanks.
