Old 01-04-2021, 01:34 AM   #14
TheChairman   TheChairman is offline
Originally Posted by putterputter View Post
What is making think it is too lean is that i always have use a full choke no matter what the temperature is outside, and have to run it for about a minute before it will idle with the choke off. I have my idle set at 1500 rpms
You're close, then. You might try notching the sealed idle air screw, removing it, and replacing it with the adjustable one to see if that makes the choke a little less needed. That is going to richen up your idle mix before replacing the slow jet completely.
Another note about gas, octane aside. Some stations sell "top-tier" gasoline, and some don't. The octane doesn't matter. It either is, or it isnt. If you want better gas, you have to go to the stations that sell it.
https://toptiergas.com/
