Originally Posted by TxTaoRider
I'm real sure the front will swap, pretty sure the rear will. I'd tell you how the 21" is going to mess up your speedometer, but since they are usually way off to begin with, it probably doesn't matter. Lol
I wouldn't be surprised if the 21 in front actually helps to improve the speedometer accuracy. On my Brozz I added a compensating device called a SPEEDDRD. It lets me adjust the speedo either up or down by a percentage. Going 12% down put the speedo close to what I get with a GPS. I don't know for sure, but I suspect that might be close to the difference between a 21 in front wheel to a 19 in.
John
