Old 03-20-2021, 08:16 AM   #3
Bruces   Bruces is online now
That seal should be the same as a Honda horizontal engine (z50-ct70’s etc) ,but before that check the crankcase vent to make sure it isn’t plugged,kinked or if it has a filter in it check the direction of the filter .If the vent checks out (it’s near the engine mount ) ,when you re-install another seal ,put a thin bead of rtv around the outside while doing it .
