Did you change the plug cap or did you use the one that came on the nibbi coil? I have the same coil installed but was wondering if I need to change the plug cap. I've heard all sorts of things about longevity issues if using resistor cap and plugs with the cdi units. I do have the ngk plug installed and haven't had any issues but figured Id better look into it preemptively.
