Bit of an update, Essentially i did find out what gear ratio was in the rear diff which is 3:54. As shown in the What did you buy thread i have recently started working out a deal on a '99 KZ Sportsman 25th anniversary 27 ft 5th wheel camper trailer with a slide out on it. So work to the truck will be focused on getting it ready to pull this trailer. There will be a hitch that comes with it so that saves some expense. I have also got a lead on a brake controller. So to that end it looks like i will need to do the following to the truck.
Install brake controller
Trans cooler
Aux engine cooler
Aluminum transmission oil pan which will allow me to increase capacity a bit as well as fit a probe for a temp gauge. A similar diff cover will most likely get fitted
New carb and fuel pump
17" Wheels to fit the used 17" tires i got for the truck awhile ago.
Air bags on rear suspension.
Eventual plans for the truck.
LED lights
18 gallon aux tank to replace under bed tank
Resized the pic of the trailer to show what the truck is being upgraded to pull
Past bikes:
'10 Gio X33
'85 Honda VF750F Interceptor
'80 Honda XL185S
'76 Yamaha DT250C dual sport
Baja Wilderness Trail 250
'07 Honda Shadow 750 Areo Trike
'01 Harley Davidson Softail Deuce
Polaris Magnum 425 4x4
Originally Posted by andyj812
You can't pin this one on me, my wife is still mad at me. I don't need your wife mad at me too. LOL
Originally Posted by 2LZ
Disclaimer: The above post by 2LZ is in no way the view of this site, other members or Bruce's llama. It is the opinion of 2LZ and 2LZ alone. ;-)
