Old 08-02-2021, 04:24 PM   #1
Lukas   Lukas is offline
Dear charles, currently my bike is 249cc and the map is for 249cc, only when I buy a 299cc cylinder, it is possible that such a map will be created, I can make a video from A to Z, how to download the bin. ECU and how to upload TO your own ECU file, which you then send to oldschool tuning, you can write that you want one like mine and they will send it to you. When I change the cylinder, maybe I will be able to make a map for 299cc, in fact this is my goal, but there are still some problems, but it is possible that I will be able to solve them Now the bike runs really well, I can go to 5th gear, at 4000 RPM it accelerates nicely, before to 6200 RPM nothing was terribly mulled I also have the second map more powerful, but the bike does not run as it should, because you can not add parameters endlessly, but it may be ok on a larger cylinder.
