Originally Posted by XLsior
On the starter relay. the 2 large posts take a direct 12v feed from the battery to the starter motor, Use the same gauge wire for cranking amps.
the 2 smaller posts are the push start and earth (green wire). when you push the start button (yellow&red wire) it activates the relay closing the 2 large post circuit so the starter motor get 12v.
All solid green wires are ground/earth terminal end wires. (The main ground wire might be black)
All solid black wires are 12v ignition on.
All red wires are 12v live.
Everything else will likely serve a specific purpose.
I ended up replacing and uprating the main ground, 12v ignition and 12 live on my replacement loom as the Chinesium loom kept frying itself.
Ok, so a total of 4 wires should be running to the relay posts, 2 from the starter housing and 2 leading to the battery posts +/- ?
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster,
