Old 12-22-2021, 10:56 AM   #2
mikegolf   mikegolf is offline
Originally Posted by ChopperCharles View Post
FYI, my 2017 RX3 also pops out of 6th gear. 7000 miles on the clock, but it's been doing it for the last 3000+. Basically, when shifting into 6th I have to be careful. I preload the shifter, clutch, shift, and I feel the shifter move halfway into gear. Then I let the clutch out slowly while maintaining pressure on the shifter, and it will proceed the rest of the way into gear. If I mistime the clutch/pressure action it will pop out of gear into a false neutral. It does this mostly when hot. Hot days plus hot motor. It does it less frequently in the winter, but still does it.
Charles.
same thing happening to me ... around 9000km on the odometer now.
Please let us know if you figure out the problem
