Old 02-02-2022, 01:39 AM   #7
slinghigh   slinghigh is offline
rebuild till new gets there
Originally Posted by pmilly03@gmail.com View Post
Wow those were fast replies! Thanks guys for getting back to me fast. I will try and solve the problem tomorrow. I should be able to get it done with the information I got from you guys. Thank you!
The solenoid might have screws or you may have to pry open....and you will see contact discs that you can sand or file down and see if there is a reason it got stuck and clean the area thats sticking little wd and put back together...had a chevy when it got hot I had to hit the starter w/ solinoid attached and it would start...its temporary for sure..
