Old 03-08-2022, 10:46 AM   #1
wlfpck   wlfpck is offline
Originally Posted by ChopperCharles View Post
So just curious... why would you buy anything except the Benelli TNT135? It's faster, bigger, and better than all the other minibikes, including the Grom itself.
Charles.
Probably should just make this discussion a different thread... but...
Reasons people got the Grom Clone
1. TNT 135 was not out at the time the Grom Clones were first out.
2. Grom clones can use Grom Plastics and parts other than engine stuff. Makes finding replacement parts a LOT easier.
3. Grom clones are SUPER cheap. Before the pandemic, you could buy one on some websites for under $1000. TNT135 is not that cheap.
4. Grom clone takes a 190CC swap. Which is direct bolt-in and plug and play swap. The 190CC takes a bore kit that makes it 212CC. The TNT135 bore kit makes it a 155cc. No larger bore kits available for the TNT135. The nc450 swap that's been done on the TNT135 is around 8K. MUCH more expensive than the Grom clone.
5. Grom clones use pit bike engines. This makes parts SUPER easy to find as most are based on the Honda CRF50 engine not to mention TONS of Chinese made pit bikes.
Reasons to get the TNT135.
1. Fuel injected.
2. Bigger front forks.
3. 5-speed.
4. Actual Trellis frame (much stronger).
Now before anyone thinks I have a bias towards the Grom Clones... I don't. I've owned one. It was fun to tinker with. I sold it.
I wrote this guide as a way to consolidate all the information I had found/researched/put together/figured out myself. That's pretty much it. The guide is NOT a comparison of the Grom clone to the Grom, Z125, TNT135, KP Mini, etc etc.
Just simply a guide.
My personal opinion on the minibikes...
If you want to tinker. Are mechanically inclined/savvy. Have the patience to tune a carb and diagnose issues. A Grom clone isn't that bad.
If you just want to get on the bike and ride it... probably look somewhere else. Like the TNT135, Grom, Z125.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
