Old 03-11-2022, 02:28 PM   #4
Boatguy   Boatguy is offline
Boatguy's Avatar
Originally Posted by China Rider 27 View Post
There is maintenance and then there are worn out parts. Worn out parts are a safety concern. By now you should have developed an appreciation or shall I say "fondness" for this bike and that may motivate you to prolong its use as long as possible which means doing the 4000 mile maintenance and might your feelings move you further to consider improvements? Personally I would like to see the inside of your swing arm bearings and headstock if you get ambitious.
How about if I just test those? You know, lift the bike up, rattle things around a bit, see if there’s any play?
And you are absolutely right. I am enjoying the bike and developed a fondness for sure.
I will probably go over the whole thing with a fine tooth comb and take a bunch of pictures
2020 Lifan x-pect
