Yaa posted that and then saw your response. A sock over the air filter to me says you are restricting air flow, which you should be able to do with the pilot air screw. Sometimes when tuning at least myself I try to go to fast to get there and so I don't evaluate each position maybe as thoroughly as I should, needle position, air screw. The answer to me, if there is a good one, has to be some combination of pilot and needle position that will work. But maybe a foam pod filter will give you the air flow restricted so to get a pilot and needle position to work.
