You are clearly on the right track. I see that sprung lever dropping into place into the detent, and not sure why the loop thing that "grabs the star shaped extensions" isn't turning it. Can you use pliers or something to see if you can rotate the thing directly? Like, place the two jaws on either side of it and just twist? While rolling the rear wheel, of course...Just trying to think of a way to bypass the gear shifter controller that turns roller that controls the dogs to shift it.
