Old 06-22-2022, 07:44 PM   #16
Teklock   Teklock is offline
Originally Posted by JFOlivier View Post
Hooked up my computer to the ECU and connected started recording a logfile and went for a short ride with the computer in a backpack. First of all a note came up saying that the ECU was primitive and only refreshed every second. When I look at the dashboard I can see movement in the engine speed, see the engine temp and all sorts of other useless information. Of particular interest is my altitude of 1533 meters when in actual fact I am not much more than about 20 meters above the chesapeake bay. Also the play logfile has me down as a Lifan CTS 125cc xml whatever that is. Still in the dark here can anyone add some light.
John
I'm not sure what you are trying to do. If your intention is tuning, you need to be able to download the complete flash. When you select 'Download entire flash' does it download a bin? If it does post it here.
I would advise reading all of the 'help' docs included with the app. It tells about the xml file and how to fix some of the "errors".
