Old 11-27-2022, 11:15 AM   #9
WindMindMusic   WindMindMusic is offline
WindMindMusic's Avatar
Temp M comes with the venerable, and AWESOME ZS172FMM-3A (visible on the stamp behind the gear shift). It has a 13T front sprocket.
I had to grind down the cast alloy shroud just to mount a 14T 520 sprocket.
Can you a pic of your 16T (!) mount?!? It must be TIGHT!
I’ll post a pic soon. I carefully dremeled down 1 inch in the guard and the clearance is very tight, and I’m running a 1/4”-1/2” slack chain because of it. I took it slow at first. Yesterday I put 40 miles on it at speed.
First road ride X-Pro Templar 250M https://youtu.be/k3kA_JZEGyk
Windscreen: EGO BIKE Smoke 18*16 Tinted... https://www.amazon.com/dp/B019Z6VA4Y...p_mob_ap_share
16T 520 front sprocket: WPHMOTO 520 20mm 16T Chain Front... https://www.amazon.com/dp/B0865YF176...p_mob_ap_share
Simple, cheap exhaust wrap: Titanium Exhaust Wrap 1" x 16'... https://www.amazon.com/dp/B073ZBF72X...p_mob_ap_share
