First of all... the add keeps saying the bike does 80+ miles/hr..
Not going to happen. Max speed on the speedo says 80 but you will never go 80 unless you are being towed. Don't expect freeway speeds out of it.. I am comfortable riding on roads with 45mph speed limits and the bike transitions quite nicely from trails to streets.
The dude is obviously a drop shipper, if he sells you a black and sends you whatever,, he is not keeping any inventory. I hope your issues work out.. I'm sure they will.. It is a good bike.. aka known as a DB-05.. I had to replace the battery earlier than I would have liked... Might have been my doing as these batteries should never be charged at a rate higher than 2 amps. Also had to do a c-clip adjustment on the carb, but it was no big deal.
KW. See the thread on clip adjustment for the carb.. it helped my Roketa, especially for hard starting.. and its pretty easy to do if you remove just remove the gas tank.
NET
2006 HIBIRD QH200-st atv, 2005 Kinroad 200GY-01, 2006 Roketa DB-05, 1980 Kawasaki KZ440 LTD
