Old 02-13-2023, 12:00 AM   #43
Got the motor reassembled, valves adjusted to (Mr. Ratio's) spec, the compression release installed and adjusted, and the last oil lines run today. Glad it's finally together.
Next, prime the oil system and check for leaks. These bikes are dry sump with a separate oil tank. The oil pump has a feed and scavenge side. Fingers crossed.
If that all works out, then it will be install the new battery (positive ground), fire up Uncle Lucas, pray the Magic Smoke stays inside the wiring, and check for spark.
