Originally Posted by Dynamo
I see Herbie had drilled & tapped the mirror location near the front brake lever location, was that hard to do??
No, it's not hard to do at all. I used a 10mm tap and the appropriately sized drill bit. The drill bit size is on the tap, if you need that let me know. Just make sure your drill bit is centered where you want to make your hole and don't go too deep.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
