Probably need to go with baseline carb settings, make adjustments back and forth (rich or lean) and fine tune the carb to your area and altitude.
Taking a carb out of the box and installing it doesn't mean it's going to work for you perfectly, by any means.
How about posting pics of the three carbs you tried to use, maybe one would be the easiest to dial in and work the best on your bike.
