Old 07-31-2023, 10:27 PM   #10
XLsior   XLsior is offline
XLsior's Avatar
Spring thing
Found the rusted timing advance unit in the bin from the 81 donor.
Thankfully it had the only still intact tension spring.
took measurements and order a pack of 10 stainless steel
20mm long 5mm outside diameter and 0.4mm thick wire tension springs
expected shipping from aliexpress is a month away. But finding a genuine OEM Honda replacement would cost 10x more.
Just needs to make the bike run...
Also having doubts about the JB case/thread repair holding the head and providing enough gasket clamp pressure...so I am making a decision to JBweld the head stud into the case...if i can find where i put the JB weld is the issue right now
