Old 09-29-2023, 05:09 AM   #7
Mudflap   Mudflap is offline
An engine needs air, fuel, compression, spark at the right time. You say it has spark and fuel. Is the spark plug wet or dry. What is the color of the plug? Good plug like NGK or questionable brand like Torch? Air filter clogged or something blocking air flow? Will it run on starting fluid? My advice is to check the valves or check compression.
