Old 12-16-2023, 10:53 AM   #44
dugndeep   dugndeep is offline
Changed my oil yesterday after 20 hour break-in period,there was a few metal shavings in the oil,just from the manufacturing.I just went back with conventional 15W40.I'll go synthetic next time maybe.Even after drilling a 2-1/2" hole in the skid plate it is still hard to get the drain plug with spring and filter screen started.So I used the winch to winch it up off the ground and was able to get under it,I used 2 jack stands under just in case something give & was able to get it started & screwed back in.You can only do it from the left side because the drive shaft to the front axle is on the right side.
