Correct me if I'm wrong, but the Templar uses a PZ30
. Although I can access the fuel mixture screw without taking it off! You couldn't? What nibbi did you get? I have a keihin PE laying around, but honestly the PZ30 and the keihin look pretty much exactly the same. I'll probably replace the stock carb once it gets a little bit warmer, but for now I'll mess with the air mixture screw.
EDIT: Scratch that! That wasn't the air screw, that was the "DRAIN YOUR GAS OUT OF THE CARB" screw! Won't be making that mistake again. I guess I can't access mine easily either. Bummer.
Originally Posted by bigdano711
What carb does the Templar X use? Are you able to access the airscrew without taking the carb off? This and the needle shimming nonsense (you can only adjust the needle in one direction) had me deleting the PZ30 and going with the Nibbi.
