Old 01-12-2024, 10:28 AM   #13
GypsyR   GypsyR is offline
GypsyR's Avatar
Out of my rather large collection of screwdrivers, there's only one long, lean, whippy, and slightly bent one that I can easily use to adjust my idle mixture. I make SURE I know where it is now because to start with I was struggling to use an extra stubby screwdriver which was annoying.
I shimmed my needle like everyone said being not far above sea level but ended up putting it back stock due to misfire at cruise. Right at the speed I ride to work at. Without the shim and bumping the low speed jet one more size richer to compensate I think has mine dialed in about as good as it gets. Not all these bikes are quite the same apparently, you do have to tune for yours and where you are.
