Old 03-30-2024, 10:58 AM   #24
Originally Posted by warrenpeas View Post
its only a tight fit for the throttle cable on the pwk32 carb. only about 1/2 inch space between the throttle cable and the tank.
you see that blue hose connecting the carb to the manifold? im going to try a piece of 1.5 inch diameter pipe instead of this silicone blue hose to connect it to the manifold i think because i can feel that hose slightly collapsing and expanding when the engine is running. the frame is in the way so that 3 inch section of hose is needed to move the carb back close to the rear tire to clear the frame . im talking about the side section if the frame being in the way because that manifold angles to the right and i cant find a better manifold one because it needs to be oval not circle to match intake port on the motor.
It is amazing that you squeezed it all in there. I see no upper engine mount. Can you fabricate one to the stays (or even from one stay) coming down beind the cylinder?
And you managed to get oil cooler/lines in there too. Wow.
