Originally Posted by Megadan
I can't even find that style for the front. I almost wonder if it wouldn't be easier to change out for a 2 piston caliper like the Hawk and other standard fork bikes use. The mounts on the fork lower may be the same. I could measure the spacing of mine to see if it is.
If you could measure that would be cool.
Can I use a two piston one for this disc? Is it compatible? Which one should I use? I'm a bit confused really.
