Thanks again, Bill.
I will start with wiring it to the battery (w/ relay and switch) first, and then go from there. Well, I actually started with a battery. I just found a YUASA from a 08 Ninja on ebay that will replace the factory battery.
I have that signal dynamics voltage monitor here. It arrived yesterday, and should be a quick and easy wire in. This is a good time to consider a small fuse block for this stuff, too. Might make it a little easier.
Thanks for the links. I'm off to read now.
