I'm far an expert, but my advice would be to put the starting fluid down and start with the basics.
You need air, fuel and spark. Make sure there's gas in the tank and the petcock is on. Make sure the plug is gapped correctly and that it provides a spark. Make sure the intake isn't restricted.
I've never really had to go beyond those basics myself...so maybe that will get you closer to the problem.
Also, check the choke and throttle cables to make sure they are working smoothly. It's fairly common to put the carb slide in incorrectly.
Hope that helps. Good luck. I'm sure someone else will have more detailed advice to offer.
2008 American Lifan LF200 GY-5 (930 km) - Sold
2007 Kawasaki EX250 - Sold
2006 Kawasaki EX650R - My new ride!
2005 Kawasaki EX250 - A new project
