Carb Hosr
I do have a question for you all. If you look at the picture where I am pointing to the choke lever you will see there is a rubber hose coming out of the carb. I would expect this is just a breather hose.
I ask about this hose because it is quite clearly easy to knock off and not notice when poking around for the choke lever. I have already knocked it off this unit, and when I check my other 50cc, it was gone too.
Is the hose necessary?? It is obviously an air line but will the unit run normally without it?
