http://motors.shop.ebay.com/i.html?_...506.m270.l1313
I hear you. It's a 10 minute job though if that. Turn off fuel petcock and disconnect fuel line on either end, pop seat off with keylock, 2 bolts to remove the fuel tank are obvious then the tank slides back and off and there it is on top of the frame just under the tank. The right one will be obvious when you compare.
