battery drainage
try turning the kill switch on.. or check the ground wires.. if you do not have a good ground it could drain the battery.. also .. check the motor cooling fan.. I have the fan sensor send power to the fan while everything was off.. it did not turn but there was a small amount of power sent to it .. so it drained the battery.... some atvs have REMOTE controls.. they require power as they are armed and ready to use.. remove the fuse or turn the kill switch on.. DOES the battery hold a charge if you dis-connect for those 2 days????
