04-12-2017, 11:33 PM | #1 |
Brozz plastic fender mounting question
OK guys I have two very important questions
#1. How do you mount the front fender ? Can someone please post some pictures . I don't know maybe it's just because it's 1130 and I'm tired but I can't figure it out . #2 The rubber washers for the plastics go in between the plastic and the bike correct ? Thanks guys
2016 Green Bashan Brozz. |
04-12-2017, 11:43 PM | #2 |
#2 Screw, steel washer, then rubber washer. Did I not go over the front fender in my video?? I know it had me stumped.
#1 It's a stupid design. First, two screws must be removed from the tree holding some sort of bracket, can't remember. Then the metal part with the spacers mounts to the tree with the bolt (X1) that's about 2" long. Make sure to either have bolts temporarily installed into the front of this (x2) while you tighten that rear one you risk them not lining up once you bring the fender up. Two little short bolts now go into the rear and the longer ones into the front. Don't forget that metal support while your holding your tongue and dancing
Brian Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com "Imagination is more important that knowledge" Albert Einstein |
04-13-2017, 12:58 AM | #3 | |
The metal part with the spacers does it face up or down?
04-13-2017, 07:13 AM | #4 |
Flat plate goes down. One single bolt in the rear at the peak of the v shape. The other metal bracket for the fender support should be placed inside the fender with a screw and fingertight them until it's supporting itself.
04-13-2017, 07:16 AM | #5 |
Yea this had me scratching my head. I bought some rubber spacers to put between the fender and the tripod metal piece which caused me to buy some longer bolts.
2016 Brozz |
