04-15-2017, 01:17 AM | #1 |
None of my electric .on my hawk comes on after i tried to install the battery
Is there a fuse box for this bike? Because none of my electric would come on after i was trying to install the battery with the bike on (stupid me). Any help guys? I cant kick start this bike for the life of me. I really didnt think this bike is a piece of shit, but it really is
04-15-2017, 02:00 AM | #2 |
Did you charge the battery after you added the acid? The bike does have a fuse and it's inside of a small white case. Mine has black tape around it because that's how I roll...
04-15-2017, 02:03 AM | #3 |
I'm putting mine together, too, and I found loose connections at the terminals on what looks like a starter relay, located just aft of the battery tray. Check there.
04-15-2017, 06:13 AM | #4 |
Everything was working fine until I tried to put the battery back in after charging it. I shorted something out because nothing will come on even with jump start
04-15-2017, 07:52 AM | #5 |
Sounds like the fuse or a connector came unplugged
2016 Green Bashan Brozz. |
04-15-2017, 08:00 AM | #6 |
Did you check the fuse?
04-15-2017, 12:13 PM | #7 | |
04-15-2017, 01:40 PM | #8 |
Generally if you lose all power it is either the main fuse or the battery ground is loose on the frame and not completing the circuit. I've had the same thing happen on my TT 250 a couple of times and in every case it was the fuse. No power to everything and once I swapped out the fuse it was fine. The last time it happened I just started carrying fuses with me but I did notice that the fuse holder was starting to melt a little so if it happens again I'm going to swap it out for a newer style that takes the blade type fuses.
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18. |
04-15-2017, 02:03 PM | #9 |
I would think that should be one of the first mods to do to one of our bikes. I was having trouble with my fuse holder not making contact but not now after swapping out to the blade type holder.
04-15-2017, 03:32 PM | #10 | |
04-16-2017, 01:53 AM | #11 |
Maybe he posted after he got leg pump and his foot hurt because he wasn't wearing boots when kick starting? The Hawk only has one fuse and if it is blown the bike won't start. Pulling the spark plug out and checking for a spark would show you that.
It's the Easter weekend and maybe the OP will post later about POS Hawk...
04-16-2017, 09:45 AM | #12 |
Maybe he got the Easter bunny to fix it for him ,he has not been back in a while .
