03-23-2011, 01:33 AM | #1 |
Inverted fork question
I have them on both the new Q and my Hondanoid....though the machining is a tad different, I'm sure they're the same beast.
Has anyone had them apart enough to figure out how to tighten the preload? Like maybe gutted them for seals, at some point? I think I've asked this before.....but on Mrs 2LZ Vic Kingpin, I can just take off the top cap and crank down on the nut a few more turns to stiffen them up a bit. I MUST change out that wimpy fork fluid in the new Q, as I did the Hondanoid. It made a TON of difference putting in some name brand 10W. The Q seems a bit saggy in the front for my 200 pound frame.
03-23-2011, 01:37 AM | #2 |
I'll be watching for responses. Son of Weldangrind and I have a Hummer with inverted forks, and I've never messed with them.
03-23-2011, 01:59 AM | #3 | |
Re: Inverted fork question
03-23-2011, 10:43 AM | #4 | ||
I've done the oil prior on the Hondanoid and both the Hensims and it made a world of difference. I'm hoping it does the same on the Q.
03-23-2011, 12:51 PM | #5 | |
03-23-2011, 12:54 PM | #6 |
I think MCM has a tech thread on changing the seals on a Q which might be useful.
Happy to serve. |
03-23-2011, 01:00 PM | #7 | |
03-23-2011, 01:06 PM | #8 |
Just checked. It was fork oil. Should still help though.
http://www.mychinamoto.com/forums/co...-documentation
Happy to serve. |
03-23-2011, 03:37 PM | #9 |
Yep, that was me. I did this again when I switched to 20w oil. As I see it, you can do two things beside changing the oil to get better damping. One is to install spacers under rather on top of the pipes. This type does not lend putting spacers on top like "regular" forks. If you think about it this makes sense as the forks are inverted; everything is opposite. The spacers would have the be the diameter of the sleeve that is on the pipe rather than the pipe itself. The other is to take the springs to a shop and purchase longer and/or more 'Progressive' (hee hee) ones. Here's the parts laid out.
03-23-2011, 04:34 PM | #10 |
Awesome! Thanks! That answers my question.
How'd you like the 20w?
03-23-2011, 05:41 PM | #11 |
I didn't notice a lot of difference. I was trying lessen the diving that I get sometimes at slightly hard stops. It helped some but I didn't want to go too far as the ride is very nice.
