04-26-2018, 10:12 PM | #1 |
Need Hawk longer clutch cable
Hi,
I'm looking for longer clutch cable for my Hawk. Anybody know of one? Thank's |
04-27-2018, 05:13 PM | #2 |
Why do you need a longer one? Taller bars? Different carb?
04-28-2018, 04:23 AM | #3 |
I think the better question is, how long of a cable do you need? That will help with figuring out potential off the shelf options.
Otherwise, you can build your own clutch cable with a Venhill clutch cable kit. Then you can make it as long as you need/want.
04-28-2018, 10:23 AM | #4 |
I'm with Dan, a throttle cable is a pretty standard item and you could get by the length a lot of places, but I'm curious why your needing a longer one also....it sounds like your doing something a little different that the stock option.
04-28-2018, 11:01 AM | #5 |
When I needed a new one I searched eBay for a clutch cable for a Taotao 250 ATV. It came up with 3 or 4 different lengths. Because the Taotao 250 has a CG engine the cable was the same as my old Lifan and probably the same as your bike. Make sure to compare the length of both the inner and outer cable before ordering.
10-15-2020, 10:51 PM | #6 |
The clutch cable broke on my Hawk today. Anyone know what other bike's cable I could order that would work? $40 is kinda redonculous for one through the companies that carry OEM Hawk parts
10-16-2020, 08:30 AM | #7 | |
10-16-2020, 08:12 PM | #8 |
Tt250 cable works. I found the cable to be too long because it maxed out adjustment right out of the box. Won't be able to stretch much. Anywho, it still works.
