03-18-2018, 06:59 PM | #1 |
New Rx 250 Build Questions
new to the forum just got my 2017 Apollo rx 250 delivered last Saturday. Never rode bikes before so this is my first bike but i have worked on cars so i have some type of knowledge. started building it almost ready to run. I have changed the oil and waiting to install the battery because there is few questions i have and dont want to mess any thing up
PICTURE 1 where does this goes ? PICTURE 2 is this the chain tensioner ? it did not come on the bike it was in one of the boxes when i got it PICTURE 3 is this the idle adjustment screw ? PICTURE 4this hose is coming from the bottom of the carburetor i think but does not plug up to any thing where does this go? hopefully you guys can help me with these questions want to get t running in the next day or two |
03-19-2018, 01:52 AM | #2 |
In picture one, just leave it the way it is
In picture two, it is not a tensioner. You will make the chain adjustments at the rear axle. The manual that came with the bike has the suggested amount of slack Change the oil that came in the bike from the factory before running. I use the gn4 Honda 10/40w. Some people suggest the rotella 15/40 t4 oil Picture three is the idle adjustment screw In picture 4 the hose routes to the bottom of the bike. It does not plug into anything. |
03-23-2018, 07:10 PM | #3 |
thank you and would you know of a better battery for these nikes?
03-23-2018, 10:41 PM | #4 | |
http://store.orionmotors.nl/ shows a good old "wet" 12N9-4B-1 (ie. YB9-B) which Yuasa don't had AGM (dry) equivalent... Motobatt had a 11Ah http://www.motobatt.com/MB9U that similar in size / Short of $ = https://www.chromebattery.com/detail...ery-yb9-b.html | https://bikemaster.com/motorcycle-ba...eries.html?p=2 is the gel version Try lightweight LiFePO4 if u trust newer tech
03-24-2018, 08:16 PM | #5 |
would those two last batteries you showed be good for headlgiht and brake light being installed id like to put those on this bike
03-24-2018, 10:37 PM | #6 | |
If you aren't looking for anything fancy or street legal, then a simple toggle switch or push button switch and a common power feed off the battery can be done to turn both off and on at the same time. The simplest and most reliable way to do this would be to use a switch to ground on a relay, then have the relay send power to each light, then ground to the chassis at each end. This will save having to run miles of wire back and forth on the bike, and be safer. Just make sure to put an inline fuse somewhere on the main power wire to the lights before it splits off between the front and rear.
03-28-2018, 03:39 PM | #8 | |
http://chinariders.net/showthread.php?t=20510 This is the one I purchased, and a buddy of mine purchased. He installed his, and he was very impressed with how the bike improved. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
05-06-2018, 01:21 PM | #9 |
can some one let me know if this is the right carb that would fit on the apollos?
https://www.ebay.com/itm/360100626734 could i order this one and would it work and fit properly |
05-11-2018, 05:22 PM | #10 | |
