Old 05-19-2016, 03:12 PM   #1
GeneralTso   GeneralTso is offline
GeneralTso's Avatar
Won't start? (FIXED)
Okay so had to step away before I got all Clarke Griswold, but the darn thing won't turnover now. Have gas, spark, haven't messed with anything sin e I had it running the other day. Not sure where to go next.
Maybe I need to adjust the valves? I know that can make it hard to start.
Also does anyone have any idea what I should expect to see on a compression test?
Man I hate this ko d of annoying stuff, need a battery this kicking is for those young fellas!
2005 Kazuma Cheetah 200 (Swamp Thing)
Old 05-19-2016, 05:40 PM   #2
Adjuster's Avatar
Maybe broke a bunch of junk loose in the gas and the carb is blocked up?
Old 05-19-2016, 06:00 PM   #3
yea, throw a little gas in the plug hole , it should pop.
Old 05-19-2016, 06:37 PM   #4
GeneralTso's Avatar
OK, I'll give it a try later. I was going all worst case ha-ha
Old 05-19-2016, 06:55 PM   #5
farmbath   farmbath is offline
Kill switch off/on?
Old 05-19-2016, 07:18 PM   #6
Azhule   Azhule is offline
Originally Posted by farmbath View Post
Kill switch off/on?
Speaking of those "Kill Switch wires"... maybe one of the "Safety/Kill Switch" wires got bumped/removed during everything you have been doing? ... I've done that before when I was replacing things on the Kawasaki, eventually I bypassed them when I found out 'faulty safety switch wires' was the reason I was left 'stranded' one day
Check the Neutral, Clutch, Brake 'safety/kill switch' wires (if it has any )
Old 05-20-2016, 12:16 AM   #7
GeneralTso's Avatar
Yeah that was my first thought too. Didn't find anything though.
Old 05-20-2016, 12:18 AM   #8
You know, the perfect solution for that kill sw on the odd occasions I happen to use it would be to replace it with a momentary switch. That way you won't forget it has been thrown and sit there cranking and cranking like an idiot which I confess to have done.
I guess it's useful for turning over the engine without ignition for some reason.
Old 05-20-2016, 10:35 AM   #9
Please clarify for me; you said it won't turn over, and then you're asking about compression and valves. Are you saying it will turn over with the starter, but won't fire?
Loved the Griswold reference.
Old 05-20-2016, 05:13 PM   #10
GeneralTso's Avatar
No battery so just kicking it. It will kick over but won't fire. i did try spraying starting fluid in the carb and it kicked over for a second so I'd say I have a fuel issue.
Pulled the gas line from the petcock and fuel does come out of petcock, pulled fuel line off carb and fuel is making it that far, next step is pull the carb and see if I can find anything. Carb is right out the box, was firing on 2nd/3rd kick so not sure what changed.
All I've done since last time it ran is reinstall air-box and attach throttle (no more vise grips).
Damn Murphy I guess.
Old 05-20-2016, 07:17 PM   #11
Adjuster's Avatar
When you twist the throttle and let it go can you hear the carb slide smacking/seating back to the bottom of the carb slide tube? You should hear metal to metal as the slide seats back into the bottom of the tube.
Did you mess with the choke at all?
Try turning the idle screw up higher.
Has to be something to do with the installation of the throttle.
Old 05-20-2016, 07:55 PM   #12
GeneralTso's Avatar
Yeah slide seems fine, no change to the choke but has to be something along that line. I'm going to pull the carb tomorrow. It wants to run not electrical thank God.
Old 05-20-2016, 08:08 PM   #13
dpl096   dpl096 is offline
dpl096's Avatar
I've done the same thing ....and it really tends to upset one's delicate mental wellness balance when it occurs.
― Thomas Jefferson
Old 05-20-2016, 08:50 PM   #14
BARLOW   BARLOW is offline
BARLOW's Avatar
if you can get to the back of the carb with the palm of your hand (air tube off), cover the whole back of the carb with your palm and push the kick lever down with your hand till you feel it sucking on your hand and then stop sucking again ... hand should now smell strong of fuel and maybe be a touch wet from fuel ... if it is, try to start it (that is often a quick way to clear a jet)
Old 05-20-2016, 08:57 PM   #15
GeneralTso's Avatar
Sure why not, can't hurt. So the side that connects to the air box or the manifold side?
