01-27-2017, 02:33 PM | #1 |
Noticable change
just passed 400 miles on my 2016 hawk and the performance of the engine is starting to really change. enough to notice while riding. someone said that it would but i would not have believed that you could really tell while riding but it is that much of a difference. im running a 17/50 on the sprockets right now and it cruises at 55-60 at half throttle. top speed seems to be around 70 sitting up and 75-80 layed down on the tank. not done a valve adj yet. maybe this week. vibrations are way down too. its still really cold blooded on start up so im going up anther half turn on the bottom screw making it two turns in total to see if that helps and maybe up the jet another step to a 115. all that said it is still more fun than you can shake a stick at straight out of the box!
01-27-2017, 02:49 PM | #2 | |
01-27-2017, 03:24 PM | #3 |
yep....mileage and breakin do make a difference. I'm over 1000 now. its probably as good as it will get, but definitely better than new.
01-27-2017, 03:27 PM | #4 |
Yep, huge difference on the CG motors. Main reason why you really don't want to mod until it really loosens up. Then you can dial the jetting around your pipe and breather of choice, etc...
01-27-2017, 05:23 PM | #5 |
yep stock speedo.
01-27-2017, 06:23 PM | #6 |
just put a Trail Tec on it....
theres also a GPS version switch between info screen & GPS screen at the push of a button.. ...
01-27-2017, 06:37 PM | #7 |
Pete, Which trail tech unit is recommended for this bike? I have the digital cluster, but I would like to get some more info from the engine. I have a trail tech vapor on the DR, and I like being able to see the Head Temp and such. Thanks.
02-06-2017, 08:50 PM | #8 | |
How are you liking the digital cluster? |
