Old 06-17-2021, 10:59 PM   #1
gwowzer   gwowzer is offline
Bump Stall
My Brozz is doing great. Love the thing.
I have noticed, however, if I am mounting a log or going over some sort of obstacle that creates a decent bump or otherwise climb something that involves a bump of the bike, the engine will just die. I'm not doing anything the bike shouldn't be able to handle or motocross jumps or anything. As a matter of fact, the only reason I didn't make it over said obstacles is because the engine just quits.
It doesn't sputter, squelch, squeak, whine, moan, or bitch. It just big bump going slowly when it impacts and forks compress... dead instantly.
Any idea what could be causing this?
Old 06-18-2021, 05:44 AM   #2
I'd guess at something electrical. Maybe a wire being pinched, grounded, or a connection loose?
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 06-18-2021, 08:08 AM   #3
ChillRider   ChillRider is offline
I've heard of sidestand cutoff switches being triggered by bumps and jumps, even minor ones like climbing a sidewalk at slow speed. Some people even went as far as removing/neutering them.
Old 06-18-2021, 08:20 AM   #4
Hunnicutt   Hunnicutt is offline
Hunnicutt's Avatar
Are you running stock carb jets? I wonder if your bike is too lean. The reason I ask is that my stock TT250 was anemic prior to swapping out the factory main jet. I didn't have the power to get out of my own way. I now have a 112 and it runs like a dream.
___________________________________
2021 CSC TT250 - Silver (Mine) "Buzz"
2021 CSC TT250 - White (Wife's) "Seymour"
2021 CSC TT250 - White (Daughter's) "Gemini"
Old 06-18-2021, 09:27 AM   #5
herbie   herbie is offline
I know you can shut the bike off with the remote, any chance the remote is bouncing around on the key switch and hitting the button? Try riding in the same place with the remote in your pocket and see if it still does it.
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
Old 06-18-2021, 10:11 AM   #6
franque   franque is offline
Sometimes there's a sensor on bikes that makes them automatically shut off when a certain angle away from normal is exceeded, usually when the bike is on its side. It could be that. Does it shut off doing a wheelie?
Old 06-19-2021, 01:04 PM   #7
Doing a wheelie doesn't shut it off. It's happened when I've had the bike started with the key, so I don't think it is a remote fob button issue. I've started the bike and tugged and pulled on wiring and that won't do it.
It's almost like the bump makes the engine miss or do something weird. But is doesn't peter out, or stall out. It just dies instantly. The Brozz does not have a kickstand shutoff, or a clutch safety.
Old 06-19-2021, 01:05 PM   #8
Oh and the bike stays running if I drop it over on it's side
