05-05-2020, 11:06 PM | #1 |
TT 250 rear wheel
Anybody know if the TT 250 rear wheel and axle assembly and the brake mounting brackets and caliper parts are the same as the HAWK 250? The rotor looks different but rest looks to be the same.
05-06-2020, 12:48 AM | #2 |
Yes but depends what version TT
The newer TT has a dished rear sprocket and not sure if compatible Older TT n Hawk same design etc |
05-06-2020, 01:40 AM | #3 | |
The brake stuff is similar but you would want a TT250 owner to confirm some dimensions with you. Mainly spacer width from wheel bearing to swing arm, and the offset of the caliper mounting surface on the axle spacer/bracket mount to either end of said spacer. The caliper itself is basically the same. Likely the rotor, aside from design, is the same generic bolt pattern the Hawk and several other bikes use. Rear sprocket side of the wheel if installing a flat sprocket will require 5mm spacers and the sprocket to be mounted groove side out. About half of the rear end of my last Hawk got replaced with TT250 stuff, so I can attest to how similar the back ends are. Worst case scenario if you want to run the TT250 rear wheel would be the need to run the left side wheel spacer and all of the brake side stuff.
05-06-2020, 01:42 AM | #4 | |
https://store.cscmotorcycles.com/REA...p/55-26945.htm
05-06-2020, 07:51 AM | #5 | |
I thought the rear hub was just a CG125 etc like most all this type of bike |
05-06-2020, 07:53 AM | #6 |
I do have several manuals for USA sold TT as a guy supplied me some parts n manuals locally for the USA sold bikes
05-06-2020, 11:55 AM | #7 |
Thanks Dan for your always thorough analysis and you too Tako for your input. Do some more ciphering on it and looking.
05-06-2020, 12:02 PM | #8 |
Don't know about Hawk, but the rear caliper on a TT250 is dual piston single action. The Brozz has a single piston single action rear caliper.
05-06-2020, 02:41 PM | #9 |
The Brozz uses a different caliper...
