Old 07-14-2021, 04:02 PM   #1
Willv2   Willv2 is offline
Broke 8 spokes on rear wheel hawk 250dlx efi
Should I just buy a new wheel for 175$?? From what I know it’s pretty hard to get a wheel true on your own..
Old 07-14-2021, 06:09 PM   #2
dr1445   dr1445 is offline
This is for bicycles but the basics are the same. Having a tension gauge is a big help. I have not done a motorcycle wheel in over 50 years.
https://sheldonbrown.com/wheelbuild.html
Old 07-14-2021, 06:22 PM   #3
franque   franque is offline
If you don't mind spending a bit more ($175 is too much for a wheel that will probably fail in a similar way) , I'd send it to Buchanan's out west and have them build you a when with better spokes and a stronger, aluminum rim. http://www.buchananspokes.com/categories/rims.asp
If you do go through them, tell them it's for an XL185, assuming you have the 4 bolt sprocket and it's a drum rear hub.
Old 07-15-2021, 05:50 PM   #4
Oldenslow   Oldenslow is offline
I've heard that truing a wheel is tough, too -- but somehow i've done several with never a problem. Give it a try.
Old 07-18-2021, 03:49 AM   #5
Is the rear rim the same as a XL185?
Old 07-18-2021, 09:10 AM   #6
I'm pretty sure the rims are close, but your hawk uses a disc brake and the XL185 uses a rear drum.
If it were me, i think I'd buy a new wheel and maybe try replacing the old old as a spare.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
