10-31-2022, 02:09 PM | #1 |
Gasoline leaking out of my bike after starting(from carb) any advice? (Pics attached)
I started my bike this weekend and saw gasoline dripping out of it. I gave it a quick ride to the store and it wouldn't start on the way back, anyone every had gasoline leaking from there carb? (Pics Attached)
10-31-2022, 03:44 PM | #2 |
Float sticking. Tap on carb. See if it stops or clean carb.
10-31-2022, 04:07 PM | #3 |
As Jeffery stated. Tighten the bowel drain screw. It probably vibrated loose.
11-02-2022, 10:00 PM | #4 |
I had the same problem on my 250 and it was the float was set too high. Lots of good videos on youtube on how to set a float but basicaly you take tha carb off remove the bowl, turn it sideways and adjust the float tab untill the line on the float is in line with the bottom of the carb.
heres a good video, hope this helps CHEERS!!! |
