Secondary air injection "EGR" plug
So I removed the air injection on the side of the engine head, because it was causing back firing with my new "catless" exhaust.
Instead of making a block-off plate, I took the risky move and tapped a thread for a M12 x 1.5 bolt. There a lot of metal shavings making the thread, I used a shopvac about every turn of the thread. The aluminum head is very soft expect shavings even when tightening a bolt. I got several bolts to try. If the anodized red is too much I can always spray some high temp black primer on it. Let me know what you guys think! ![]()
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
A stainless pipe plug just came in, this might be the winner here. Can't wait to try it.
I have flat steel plates for this task.
Or you can cut the pipe n weld the hole or make a plate |
Interesting solution! I never thought of tapping the hole.
Here are some new pics. I put on anti-seize and a coat of high temp black.
I would have gone for high temp red loctite and called it a day
Again there is a plate and gasket available - just blanks it off directly
Be careful. I have heard of people shredding the rear tire from all the added power. With all the weight reduction and power, the front wheel becomes useless.
I made a blockoff plate from the iron crate the Hawk came in for my TT250 head, and put 3/8 rubber plug from the HW Store. Cost was probably 12 cents. Cheap bike gets cheap solutions LOL
1983 Honda Xl600R 2016 Ducati Multistrada 1200S DVT |
