Old 12-07-2019, 07:53 AM   #1
brixtonrider   brixtonrider is offline
Delphi MT05 sequence for imperial/metric
Is there an ignition key sequence for changing MPH to KPH (imperial/metric) reading for a Delphi MT05 ECU? The bike is a Brixton BX125, had to perform a hard reset of the ECU to clear out a fault code and that switched my clock to miles per hour.
I don't have an OBD2 reader or the right software tools to read/write MCU settings, really hoping there's a sequence for this setting as well.
Old 12-07-2019, 10:29 AM   #2
NzBrakelathes's Avatar
Not in ecu I’d say? Weird
I don’t recall seeing it in live data
Prob press button on dash then turn key on..
Old 12-07-2019, 10:36 AM   #3
The factory guy says turn on off quickly twice
File Type: jpg D97FFDF7-53BF-4889-B51F-690E0D294F28.jpg (8.6 KB, 393 views)
Old 12-07-2019, 11:19 AM   #4
Will try that. Thanks a lot, really appreciate it!
Old 12-09-2019, 05:57 AM   #5
Many thanks, that worked beautifully.
For clarity to other readers, the full sequence for switching between imperial and metric readings on the dashboard -
1. Turn iginition off for at least 15 seconds
2. Turn ignition on/off two times really quick (half a second or so each cycle)
3. Wait 15 seconds (with ignition off)
4. Turn ignition on, your readings should now be in the new measurement system
